time to upgrade (long tubes)
Old Apr 17, 2005 | 09:45 PM
camaroz28_97's Avatar
Ok im going to make this as short as possible. I have an exhaust leak and I have decided to upgrade to long tubes. Cash is low but I do want a good set. I have been looking at pacesetters. Pros and Cons? Install tips?? I live in NJ and need to have cats to stay legal (yes I know that relocating the cats isn’t totally legal) I want AIR and hi flow cats.
Thanks,
Erick
Old Apr 17, 2005 | 11:19 PM
brn_em_up13's Avatar
Re: time to upgrade (long tubes)
go with the pacesetters. i just installed a set and it was a damn easy install. I didnt have to lift the engine or anything...everything just bolted right up. I was also impressed with the overall quality of the product!
Old Apr 18, 2005 | 06:47 AM
curly's Avatar
I agree, go with the pacesetters. I also just helped with an install and it went smooth. We had te car on jackstands (about 18" high) and they went in from the bottom very easily. I like them much more than my Jethots. Good luck!!
Old Apr 18, 2005 | 07:43 AM
ShawnMacAnanny's Avatar
i went with a set of used ceramic coated jet hots from the board. Paid $300 shipped for them. Went right in without having to jack the engine up or anything.
Old Apr 18, 2005 | 08:38 AM
slverbullet's Avatar
pacesetters arent a bad choice. especially when comparing costs. i think any way you go, you will be happy you got long tubes on. might want to consider getting them coated though. makes a huge difference.
make sure to use some breslin bolts when putting the headers on. you can get them from www.summitracing.com- part #: BPP-200-076 (or a little longer ones, i forget the length needed). these will save you a lot of trouble down the road with retightening your bolts. also use felpro 1406 header gaskets. i wouldnt recommend using the ones they come with.
Old Apr 18, 2005 | 08:08 PM
anyone else??
Old Apr 18, 2005 | 08:10 PM
Kataklysm's Avatar
Due to the north east weather conditions I"d get a set of stainless steel headers. I have a set of pace setters that are ceramic coated...been on about a year and the coating is trashed underneath, its pretty much all off. Not to mention the welds on the pace setters are pretty poor. I'd save up money and buy a better set, preferably Kooks.
Old Apr 18, 2005 | 08:26 PM
I thought they were really good headers????
Old Apr 18, 2005 | 08:50 PM
I just saw a post that said kooks are 800 .
Old Apr 18, 2005 | 09:06 PM
Kataklysm's Avatar
THey are alright for the money sure. Yes Kooks are expensive but you get what you pay for.
Old Apr 19, 2005 | 12:32 PM
blind527's Avatar
Are Breslin header bolts worth it? I'll be getting a set of 12 from Summitt, anyone know a cheaper place to get these?
Old Apr 20, 2005 | 01:36 PM
I just ordered a set of pacesetters with emissions hookups . now i need cats. could i just get the pacesetters y and weld in cats?? will it fit?? of should i just get one custom made?? also the vendor said i could use the stock bolts and shouldn't have a problem?? lastly where sould i get the gaskets from??
Old Apr 20, 2005 | 02:19 PM
blind527's Avatar
I'm pretty sure you're going to have a shop put in cats for you. I suggest Carsound/Magnaflow cats on Ebay.
Old Apr 20, 2005 | 06:21 PM
Guess you missunderstood my question. I am asking if i can mod the passetters ORY to have cats. Weld them in myself. I think that this would work but will it clear the floor boards?? anyone have the ORY?? how much room is the till it hits the floor boards??
Old Apr 20, 2005 | 06:44 PM
blind527's Avatar
I didn't misunderstand. I told you that if you got cats you would have to have a shop put them in. Obviously if you don't have cats now, you'll need hi-flow ones, like Carsound/Magnaflow. I have the ORY, and a lot of people have problems with the collector hitting the floor. My headers have not yet been installed.
