Time for a rebuild..
Old Apr 11, 2005 | 12:27 PM
Bow94z's Avatar
Well i am thinking a 355 bottom end with a LE1 top end. But does Llyod make a bigger cam for the LE1 heads? Ill prob go with either Longtubes or Mids, with 30lbs injectors.
think its worth it? will i be looking at close to 400hp? Could i pull off this rebuild under 4,000$?
Old Apr 11, 2005 | 12:32 PM
SStrokerAce's Avatar
Re: Time for a rebuild..
Yeah Lloyd has had cars with LE1 heads and a LE2 cam dyno 400rwhp.
A 355 shouldn't be too much money so you should be able to pull it off.
Bret
Old Apr 11, 2005 | 12:33 PM
Bow94z's Avatar
Bret
yea cause i could reuse my block, get the machine work done, reuse the stock crank..correct? what kind of pistons are good for this type of setup?
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
