Time for a rebuild????
Old May 1, 2004 | 08:43 AM
93TArunner's Avatar
93 TA blew the dipstick up about 2 inches n shot oil out of it yesterday... now the dipstick i realized does push in more than i had it and it would probably stay in but then with the excessive pressures i'll probably blow seals left n right... the PCV valve is working.. theres white smoke puffing out the valve covers where the pcv air in is supposed to be goin... I guess i'll have to get it leakdown tested but i think itz on itz last leg.. anyone else think so?
Old May 1, 2004 | 03:40 PM
OBE1 95Z28's Avatar
Grey smoke puffing out your top end saids that your rings lands are gone...time for a rebuild. White smoke out the tail pipe means you blew the head gasket(s) - water is entering the cylinders.
Old May 1, 2004 | 04:24 PM
ZDriver96's Avatar
White smoke came out from my valve covers and PCV pipe on the Throttle body... It was a blown piston #5.. and a blown head gasket on the other head that flooded piston number 8
No white smoke out the exhaust though due to piston number 8 being flooded...
Old May 1, 2004 | 04:30 PM
CrAkD X 95TA's Avatar
everyones getting rebuilds these days
Old May 1, 2004 | 05:22 PM
93TArunner's Avatar
Nothing out the exhaust, the car has been idling really bad lately, every few seconds it would miss n drop to arround 500 rpm.. Thanks for the info.
Hey anyone know about the summit rebuild kits?? I see they have the Chevy 350 kits starting at 280 cast and w/ forged trw pistons for 390, not looking to gain power.. i just want it to run like new again
Old May 2, 2004 | 03:14 AM
ZDriver96's Avatar
that miss at 500 rpms is that piston falling on its face cuz it has zero compression... trw's are the cheap forged pistons.. they are heavier than stock pistons i believe but can handle more power..
Noenav
Mar 1, 2019 07:38 AM
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
