Time For New Injectors
Old Apr 17, 2006 | 03:42 PM
MPB70350's Avatar
Well after doing a tune up im still getting crappy gas mileage, so i figure I am going to replace the injectors, original with 70k. I am planning on doing LT's, 1.6 rr and new cam in the near future. My question is I calculate that I will need about 28-30#. Will my car run like crap until i do my upgrades? Do i need to tune my MAF for the bigger injectors? or is this just plug and play type swap? thanks guys!
Old Apr 17, 2006 | 05:20 PM
MeanGreen97Z's Avatar
Re: Time For New Injectors
You can run them but the mileage wont get any better until you get your PCM tuned for the mods you have. You know that you can get your stock injectors cleaned and flowed to run like new right?
Old Apr 17, 2006 | 07:11 PM
Jeff H's Avatar
Have you tried putting your stock MAF back in? It's known that modified and aftermarket MAF's can have problems and cause you to lose power and gas mileage. I'd try that first since it's free.
Old Apr 18, 2006 | 08:04 AM
MPB70350's Avatar
Yes i know you can get injectors cleaned but i dont know if it is worth it since it will be about 25 per injector, to get it done from a reliable company. This would cost close to the same as new injectors and im not sure if it is worth it, since i will need bigger ones shortly. MeanGreen thanks i will try that out and hope it helps!
AdsoYo
May 2, 2018 03:21 AM
RUENUF
May 25, 2016 08:10 PM
Alex Barnes
Jan 24, 2015 10:21 PM
siguy
Nov 27, 2014 10:07 AM
