ticking sound...could it be egr?
Old Apr 18, 2005 | 11:58 PM
globe's Avatar
just installed LT headers on my friends camaro. there is now a ticking sound. figured it was the crappy gaskets taht came with so i got fel pro ones and installed them. but the tick is still there so im trying to narrow it down. i did order a egr block off plate but ended up ordering the ls1 version on accident.
so im just gonna make him one but currently i have a thin piece of aluminum covering the hole temporarily.. just curious if this could make the sound cause there is a couple tiny holes in it not totally sealed.
thanks
Old Apr 19, 2005 | 01:25 AM
RedRyder518's Avatar
Re: ticking sound...could it be egr?
More than likely it is an exhaust leak somewhere. Try the "hose technique" to find where it is coming from. Get a section of pipe and put one end to your ear and the other to where you think the ticking is coming from. It will allow you to pin point it a lot easier. Also you can check for carbon streaks if you have a bad enough leak.
If you actually don't have the EGR hooked up and it is just open on the header then it will definitely make a ticking noise.
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
1slow93z28
Sep 1, 2015 06:22 PM
