ticking sound coming from front of car, seems to get faster with higher rpm
Old Apr 3, 2003 | 01:33 PM
sc93's Avatar
I am thinking this may be caused by a small exhaust leak I noticed right before the cat on my 93 Z. Could this be the knock sensor picking up the tick from the exhaust leak?
What else would cause a ticking sound?
Old Apr 3, 2003 | 01:44 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
its probobly the exhuast leak making the noise.
go get some "Tiger Paw" at pep boys
I doubt the KS would pick that up
Old Apr 3, 2003 | 02:29 PM
sc93's Avatar
What is this Tiger Paw you speak of?
Old Apr 3, 2003 | 03:01 PM
treyZ28's Avatar
exhuast wrap i've had good expierence with
Old Apr 3, 2003 | 04:10 PM
Zerosheaven's Avatar
use a little j-b weld that **** is stong as..... ****
Old Apr 3, 2003 | 07:27 PM
cop01's Avatar
is it connected to rpm or mph?
Old Apr 3, 2003 | 07:32 PM
mineralwater's Avatar
I don't think jbweld would hold up to the direct heat of the pipes - i've tried it on my header/ypipe collector, with no luck. The jbweld cracks and peels away after a couple miles.
And depending where the exhaust leak is, the KS *will* pick it up. I had a exhaust leak at the pass. side collector, and it was picking up about 6-8 degrees of kr.
Old Apr 3, 2003 | 08:05 PM
sc93's Avatar
well, both
As the car is moving (I hear it real good in the parking deck at school), and when it is sitting, if I put it in neutral and give it a little gas, it goes faster also.
That's why I feel it is the exhaust leak
Old Apr 4, 2003 | 02:46 PM
93transam1234's Avatar
m
Check ur ignition coil at night in the dark and see if it is sparking. My mark was making that noise
Old Apr 4, 2003 | 02:47 PM
Mr Freeze's Avatar
i'm no expert, but i had a ticking sound that was very similar to a lifter tapping...turned out to be a spark plug wire that was arcing to a close ground...pop your hood at night and look where your wires are running...it'll probably be a blue arc if it's a bad wire.
travis
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
jayblev95
Dec 1, 2014 06:55 AM
lbrowne
Nov 13, 2011 04:25 PM
