Is this ticking noise normal?
Old May 4, 2008 | 07:18 PM
Red93Camaro's Avatar
When I turn on my Car, it makes a fast tick noise. ( everyone says this is normal for an LT1) and when I drive around 1,500 RPMs It gets faster and faster as the RPMs go up. is this normal? Its not loud or anything just audible enough to notice.
Thanks!
Old May 4, 2008 | 07:40 PM
wrd1972's Avatar
Do you have roller rockers?
Have you ever messed with the valves?
Most likely its valvetrain related. A mostly stocj valvetrain should be rather silent, but could possibly need an adjustment.
Old May 4, 2008 | 07:45 PM
Most likely its valvetrain related. A mostly stock valvetrain should be rather silent, but could possibly need an adjustment.
I dont know what any of that means.
Old May 4, 2008 | 07:54 PM
MarcR94v6's Avatar
Mine makes rocker noise, just a whisper though, so I don't think it's a big deal....my motor is pretty fresh too.
What he is asking you is, have you done or had any work done to any part of the top end of the motor, or is everything stock to your knowledge?
Old May 4, 2008 | 07:58 PM
well, The tranny was rebuilt, and theres a Shift kit in it...Thats all I know.
Old May 4, 2008 | 08:04 PM
2000GTP's Avatar
Could also be an exhaust leak, that can lead to a ticking noise as well.
Old May 4, 2008 | 08:06 PM
It's always ticked, I just installed The SLP Loudmouths. It sounds like it comes from the Intake manifold. I'm not positive though.
Old May 4, 2008 | 10:32 PM
TeamingTealZ28's Avatar
Nothing in the intake manifold that would tick.
Probobly the valvetrain (rockers, valvs, etc)
More pain in the *** than its worth fixing it
Old May 5, 2008 | 06:01 PM
Pontiac_97's Avatar
wtf. its not a PITA. it takes like 10 minutes to pull the valve covers off and maybe a hour to adjust them all.
Old May 5, 2008 | 06:52 PM
twcblackhand6970's Avatar
Yea, there's a lot of noise coming from the valve covers to. What causes this ticking and is it bad?
Old May 5, 2008 | 07:16 PM
maybe2fast's Avatar
sounds like a lifter.
Old May 5, 2008 | 07:26 PM
Um I didnt narrow it down to the valves. I was saying it could be a number of things. Calm urself super mechanic
Old May 5, 2008 | 10:52 PM
rusnrno's Avatar
Check for exhaust leaks. Check the fitting from the exhaust manifold to the AIR pump.
Old May 5, 2008 | 11:14 PM
Dave1980's Avatar
record the sound and post it up here.
Old May 6, 2008 | 06:58 AM
I will today.
