Ticking noise need opinions
Old Nov 29, 2003 | 04:54 PM
1994CamaroZ28's Avatar
Ive posted about this before in the past, i still think its a exhaust leak but i dunno i noticed when i was driving today the sound only happens or maybe its just louder when i press on the gas doesnt matter what rpm the car is at really just hear it when i press on the gas, maybe injectors? any opinion welcome. thanks
Old Nov 29, 2003 | 04:57 PM
b-stevens's Avatar
I'd still say thats an exhaust leak... thats exactly how mine was. I just replaced the passenger side header gasket today and my god, the copper gasket was literally black around the ports. I actually think they didnt heat cycle the gasket properly on that side or just didnt tighten it enough.
Old Nov 29, 2003 | 05:00 PM
ibanez6rg's Avatar
Could be injectors. Have you done any exhaust modifications lately?
Old Nov 29, 2003 | 05:03 PM
Only exhaust mod is cutout, i plan on doing headers next month so we'll see there. i might as well order a new set of injectors also the car only has 163k miles on her like i said all opinions welcomed i dont want to chance missing anything.
Old Nov 29, 2003 | 05:09 PM
Jeff H's Avatar
It seems like a lot of the LT1's have some sort of ticking noise to it. It would come and go in my old 93 Z28. It drove me nuts, but I could never really figure out where it was coming from. I tried adjusting the rocker arms and no difference. It always seemed to get a little quieter after an oil change too. I put 40K+ miles on the engine with a supercharger and never had any problems so it probably isn't that big of a deal. If it gets louder then it could be a rod knock so just keep track of it.
Old Nov 29, 2003 | 05:11 PM
ibanez6rg's Avatar
Leave the injectors alone, get them cleaned if anything.
Old Nov 29, 2003 | 05:49 PM
black96z28's Avatar
My car had a ticking noise in it too, I checked everything, changes plugs and wires, because I thought it was a arch problem, or something like that, but it wan't turned out to be a exhaust leak. Check all tubes that run into your manifolds, like from the EGR, etc., on the drives sive manifold, where the tube ran into the manifold on my car that nut had loosen up and was causing a exhaust leak, I tighten it up, and have had no problems since.
Old Nov 29, 2003 | 06:30 PM
Joe K. 96 Zeee!!'s Avatar
Might be the exhaust manifold gaskets. I've had two leaks and they both sounded mechanical. Tick gets faster and louder as rpm's increase.
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
SEOJustin
Sep 24, 2015 04:39 PM
rideordie
Sep 7, 2015 08:22 AM
