Ticking Noise
Old Dec 12, 2007 | 09:08 PM
SlickBlack Z's Avatar
Ticking Noise
There is a ticking sound between 2000 and 3000 RPM audible from what seems to be the driver side of the engine..happens both under load and not under load. Any ideas? Mods are in sig
Old Dec 12, 2007 | 09:53 PM
mrmint69's Avatar
See where the noise is coming from. If its under the valve cover you can remove it and see what could be causing it. A loose spark plug or exhaust leak can cause ticking noises also.
Old Dec 12, 2007 | 10:36 PM
Romero155's Avatar
either a loose rocker or an exhaust leak. Take the driver side valve cover off and you can prolly narrow it down better.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
1slow93z28
Sep 1, 2015 06:22 PM
colts0455
13
Aug 7, 2015 09:15 PM
colts0455
Jul 7, 2015 07:19 PM
