Ticking noise.
Old Nov 18, 2003 | 12:27 PM
1994CamaroZ28's Avatar
Ticking noise.
ive used the search button and looked around, but couldnt find a almost definate awnser.
i got a 94 z28 a4 light mods intake exhaust etc.
when its cold its got a slower tick tick tick when it warms up abit it quietens down a bit and when the rpm is raised a bit it basically goes away what do you guys think?
Old Nov 18, 2003 | 12:37 PM
Heatmaker's Avatar
Advanced Member
Have you pinpointed where the tick is comming from exactly? usually on these cars it's the rockers.
Old Nov 18, 2003 | 12:38 PM
sounds like passanger side aroudn the valve cover ill pull the cover friday and check the rockers, if you guys think thatd do it.
Old Nov 18, 2003 | 01:31 PM
Cmr0z28's Avatar
I had the same thing. I got a stethascope, started her up, and found out exactly where the noise was coming from.....sounded like it was coming from under the valve cover, but it was actually the injectors opening and closing making a ticking noise. You can also use a long screwdriver and put your ear to the handle to find out where the noise is coming from.
Old Nov 18, 2003 | 01:32 PM
Mystic97Z's Avatar
i had the same problem,,mine was the exhaust manifold gaskets
autoxr166
Sep 25, 2015 04:21 PM
1slow93z28
Sep 1, 2015 06:22 PM
Greg88
Aug 24, 2015 07:59 AM
colts0455
13
Aug 7, 2015 09:15 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
