Ticking lifter???????
Old Jul 31, 2003 | 06:24 PM
naaz90's Avatar
I have had a ticking sound coming from the drivers side of the engine. It does get a little louder with increasing RPMs. My mechanic says its mostly likely the lifter.
Has anyone had this problem? How hard was the fix? i plan to fix the intake manifold leak anyways? Should i just go ahead and replace the bad lifter?
Advice and suggestions needed
Thanks in advance
Old Jul 31, 2003 | 06:45 PM
Cmr0z28's Avatar
lifters get noisy when they get cold......try putting marvel mystery oil in the motor
Old Jul 31, 2003 | 06:56 PM
I burn rice too's Avatar
I've had a problem with a bad lifter, it flattened out and took the cam with it. You may also have an exhaust leak or a loose plug. Try those first. I also wouldn't replace just one lifter unless you can pin point the exact one. If you have this one goin' south there is a chance that the rest will too. Just a little insurance so your not pulling the manifold again. Autozone sells the Mellings for about $11 each.
Old Jul 31, 2003 | 11:25 PM
slashz28's Avatar
i had a ticking as well a few weeks ago, wound up beeing a loose rocker you could check that pretty easily
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
