ticking
Old Aug 13, 2003 | 10:31 PM
zuluman13's Avatar
ticking
When you open the hood of my car while its running your hear a constant rapid ticking noise someone i talked to mentioned something about valvetap?
Is something wrong.
Old Aug 13, 2003 | 10:41 PM
naaz90's Avatar
Lt1's have noisy injectors. Its pretty faint but you can hear it with the hood open. Now if you can hear it get louder with RPMs, and you can hear it over road noise and exhaust then you may have a different problem.
I definently have something other then injector and normal valvetrain tick. I may have a bad lifter. But its pretty loud so if your car doesnt tick all that loud then your probably fine.
Old Aug 13, 2003 | 11:23 PM
meangreen95z28's Avatar
you might want to check the egr valve tube where it goes into the header/exhaust manifold.
Old Aug 13, 2003 | 11:40 PM
zuluman13's Avatar
what should i be checking for
Old Aug 13, 2003 | 11:50 PM
on the pass. side see it the tube is connected to the exhaust manifold good. No gaps.
Old Aug 14, 2003 | 07:58 PM
Shinigami
Guest
Posts: n/a
also check to make sure that your plug wires don't have a crack somewhere and arching against the frame... do the dark test start car at night in pitch black and take the hood bulb out look for any sparking... that would definitly make a tick sound. thats what was wrong with my 89 RS.
Old Aug 14, 2003 | 10:32 PM
Bud M's Avatar
Make sure you don't have a loose spark plug.
1slow93z28
Sep 1, 2015 06:22 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
sc93
Apr 4, 2003 02:47 PM
Chris91Z
Mar 25, 2003 02:24 PM
