tic tic tic at startup
Old Aug 15, 2005 | 06:46 PM
lt1srule's Avatar
car tics for about 15 sec at start up when cold then goes away slowly .would could cause this is it normal..
Old Aug 15, 2005 | 06:48 PM
MRBoss429x's Avatar
Re: tic tic tic at startup
How fast is the ticking? Could be an exhuast leak. Little ones tend to disappear when things heat up and metal expands, sealing the leak.
Old Aug 15, 2005 | 07:11 PM
1995GRNZ28's Avatar
I had this problem also in my 95 z28 i never got a chance to figure it out as i cracked a set of heads and had my motor rebuilt. I thought it could have mabye been the lifters but the sound stopped after awhile so i really have no idea sorry. If you find out what it is please let me know. Thanks
Old Aug 15, 2005 | 08:44 PM
Warlock1313's Avatar
loose exhuast manifold/ bad gasket perhaps. I have that problem right now but it goes away once everything warms up
Old Aug 16, 2005 | 12:27 AM
Zjoker's Avatar
Mine was a loose spark plug...the first time :
Old Aug 16, 2005 | 02:01 AM
chrisn's Avatar
if you think its a sticky lifter, run a quart of marvels mystery oil in it. that might clear it up. it did wonders for me.
Old Aug 16, 2005 | 09:38 AM
lt1srule's Avatar
yea think its a sticky lifter .motor set up for over a year befor i put it in ..thanks
Old Aug 16, 2005 | 12:58 PM
Heatmaker's Avatar
Advanced Member
I had that problem some months ago... someone hinted it might be a lifter... so when I took my top end apart I pulled the lifters... and they were worn out worse than 2 dollar harlot. I replaced them and the ticking stop and my oil pressure improved as well.
Nayr
Mar 3, 2023 08:34 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
GT what?
Jul 14, 2015 10:17 PM
2QUIK6
9
Sep 22, 2003 05:47 PM
TedH
Sep 1, 2003 11:25 PM
