Thunk noise
Old Apr 28, 2004 | 03:13 PM
RyanMacZ28's Avatar
Thunk noise
Alright, I have a slight problem, and im not sure what it is. Every now and then, around 10-30 if I hit the gas hard enough for the car to downshift, sometimes the car sounds like its gasping for air (like a choke) then a clunk noise follows.
If you need any more info let me know. Its a 94 A4 with a K&N filter only. thx for any info
Old Apr 28, 2004 | 04:43 PM
Wilson's Avatar
It could be your Transmission mount. When it broken it makes a thunk sound when you get on it.
Jack up the car and look under the Transmission cross member. You'll see a rubber mount mounted to the middle of the cross member. See if its ripped. If it is then buy a new one. Its a easy fix.
Old Apr 28, 2004 | 11:51 PM
RyanMacZ28's Avatar
already did that when the tranny mount was making noise last year ... this noise is coming from the engine .. anyone else?
Old Apr 28, 2004 | 11:52 PM
screamin94Z's Avatar
sounds like you've got a knock, could be plenty of things, is it just intermittent or does it happen often?
Old Apr 29, 2004 | 10:56 PM
RyanMacZ28's Avatar
its more intermittent, on and off
Old May 7, 2004 | 12:43 AM
RyanMacZ28's Avatar
anyone out there got any ideas?
Old May 7, 2004 | 01:20 PM
dabear95's Avatar
Could it be something that is connected to the engine (CAI for example) that is prying back or hitting something else when the engine twits from torque? Just an idea.
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
