Throttle Position Sensor
Old Nov 7, 2007 | 02:27 PM
198Z's Avatar
I've been trying to check my TPS voltage on my 93 Camaro at idle and full throttle. According to the Hayes book I should have roughly .55 volts at closed throttle and 5.0 volts at open throttle. I only have a .27 at close and a 3.64 at open. Are the numbers in the Hayes book correct? Does it sound like I should have that type of voltage? I have a TPS switch on a throttle body that came off a 94 Corvette. Can I use this one? Or does the mass air flow on the 94 Corvette use a different TPS than my 93 Camaro? Thanks!
Old Nov 7, 2007 | 03:26 PM
ricehammer's Avatar
Sounds like your #'s are off. Mine sits at 0.64Vdc with the throttle closed and about 4.5Vdc WOT. TPS's are different.
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Queens94z28
Dec 20, 2014 09:11 PM
