Throttle Position Sensor?
Old Mar 28, 2005 | 01:24 PM
Black6spdZ's Avatar
I replaced mine today because it threw a code. The code is gone but now the car idles at like 1400 and doesnt drop down, is there any adjustments or anything i can do to calibrate it?
Old Mar 28, 2005 | 02:04 PM
Re: Throttle Position Sensor?
It normally should not need any adjustment (there actually is none). You can check the voltage and throttle opening percentage with a scanner to make sure it is working correctly.
Old Mar 28, 2005 | 02:10 PM
Black6spdZ's Avatar
thats what i thought, i fixed it with the adjustment screw my throttle plates were sticking
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Queens94z28
Dec 20, 2014 09:11 PM
