Throttle body sizing
Old May 2, 2003 | 09:56 PM
llafro's Avatar
What size a throttle body should I use for a 95 LT1 with the following:
Ported and polished heads (peak flow 278/191 CFM)
Comp XE 230/236-112 (.545/.544 lift w/1.6)
new lifters, pushrods, guideplates, 1.6 rockers
SLP headers
Hi-flow cat
SLP cold air induction
I measured the holes on the intake, and they are 52 mm. Is there any benefit to getting a 58mm on this setup?
Thanks,
BRAD
Old May 2, 2003 | 10:09 PM
qwick_trip's Avatar
well if you go to 58mm tb then you'll have to bore out your intake. i would say that the 52mm tb would work just fine.
Old May 2, 2003 | 10:28 PM
Antz97ZNJ's Avatar
52 should be fine but if you decide to do future mods .ie blower,turbo etc....you might as well buy a 58....i believe edlebrock also makes a 54.....
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Jul 4, 2005 05:00 PM
