throttle body& jett chip stage 2
Old Dec 18, 2007 | 05:25 PM
trans 96's Avatar
Question throttle body& jett chip stage 2
what do yall think about the stage 2 jett chip? is it worth the money or will it mess my car up? someone told me the chip would make my car run wide open a eventualy blow the motor. is that true? what throttle body would be best for a pretty much stock lt1 with a free flow exhaust 52mm or 54mm?
Old Dec 18, 2007 | 06:37 PM
ricehammer's Avatar
I'm assuming that you have a 96 LT1 from your user name. If it is a 96 you can't change the computer chip since it doesn't have one. 96 and up are obd II and have to be re-programmed. You can however send the PCM off to PCMforless (http://www.pcmforless.com/) and have Bryan reprogram your PCM for you. And you will feel some nice gains from the re-program. If your car is 95 or earlier, PCMforless can program a chip for you to accomplish the same thing. I have one of Bryans tunes and am very happy with it.
As far as the throttle body goes, the stocker will flow enough air until you do heads/cam. If you really want to upgrade, a 52mm will be fine. IMHO a cold air injection (CAI) system will get you more power and cost about the same as a larger throttle body.
Old Dec 19, 2007 | 06:55 AM
trans 96's Avatar
on the internet it says the jet chip piggy backs onto the ecu. is that not true? also what is imho? are talking about a cold air intake? i already have the ram air on my trans?
Old Dec 19, 2007 | 07:10 AM
Bluovlh8er's Avatar
jet chips are good for busting nut on
Old Dec 19, 2007 | 07:26 AM
trans 96's Avatar
so no jet chip?
Old Dec 19, 2007 | 07:39 AM
Bluovlh8er's Avatar
they dont do much of anything. prolly from switching from 87 to 92 oct....
same power increase...................
Old Dec 19, 2007 | 07:43 AM
trans 96's Avatar
cool thanks that saved me a bunch of $$$ so just get it dyno tuned
Devinfoote87
Feb 12, 2016 03:21 PM
C4m4roJoe
Jul 19, 2015 10:59 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Boss002
Jul 9, 2015 03:33 PM
