Throttle body
Old Sep 19, 2006 | 10:12 AM
silver95's Avatar
Throttle body
How does a person know what size of throttle body they need when rebuilding an engine?
Old Sep 19, 2006 | 10:24 AM
Dave '97 Z28 M6's Avatar
Re: Throttle body
Check out this thread:
http://web.camaross.com/forums/showthread.php?t=465610
I think a 52mm is good for up to 500 crank HP.
Old Sep 19, 2006 | 10:41 AM
TQdrivenws6's Avatar
Re: Throttle body
I had a 52mm on the car when it made 409rwhp SAE through the M6/10 bolt. That equates to about 470 flywheel hp. The engine was pulling 1.5-3" of vacuum from 6000-7000rpm.
I swapped to a monoblade and made 413rwhp SAE through the M6/3.5" steel driveshaft/ 35 spline Moser 9" with 4.33s. That equates to about 490 flywheel hp from the additional drivetrain loss. 0.5" vacuum max with the monoblade.
This was on a 383 with the LE ported LT1 intake manifold, LE2 heads/cam.
The only change to make power was the switch from 52mm - monoblade. All of the gains were pretty much eaten up by the new drivetrain, but I was happy to not lose anything going to the 9".
In my personal opinion, I would go with a 58mm for any heads/cam package no matter the bottom end (350/355/383/396). I think the monoblade may have been overkill, but the car ran just fine with a little tweaking of the tune.
Old Sep 19, 2006 | 04:21 PM
silver95's Avatar
Re: Throttle body
How much horsepower will a 58mm throttle body support?
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
