Throttle body
Old Jul 14, 2005 | 01:04 AM
Jeremy_30th's Avatar
Throttle body
I am going to buy a new one probably Holley and I had a couple questions.
What size is stock 48mm right?
Intake should be @ 52mm right?
If I go to 58mm I will need to port the intake and have my PCM tuned for it right?\
With my mods 52mm will probably be enough right? I know its not a real big gain, I am mostly doing it for looks but a couple HP is good to
Old Jul 14, 2005 | 02:14 AM
1racerdude's Avatar
Re: Throttle body
A 52 will fit OK, 58 would be better, but I would have it retuned to put more fuel to it along with more air. Remember your CAI and the filter. The 6" K&N only flows 750CFM and a 52 is right in that neighborhood.A 58 flows about 900-950CFM.
Old Jul 14, 2005 | 06:27 AM
cobrakiller97's Avatar
Re: Throttle body
true a 58 would be better , but im extremly happy with my 52 you should be fine with a 52
Old Jul 14, 2005 | 06:28 PM
Re: Throttle body
Isn't tuning required with a 58mm? And aren't the intakes only opened to 52mm?
Old Jul 14, 2005 | 06:36 PM
1racerdude's Avatar
Re: Throttle body
Correct.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
