Throttle Body
Old May 24, 2004 | 04:34 PM
lookingformore's Avatar
Throttle Body
At this point in my engine re-build is it necessary to change the throttle body to a larger one..if so whats a good recommendation.......engine now has AFR heads, CC305 cam, and the rest is basically a stock re-build.......or can i re-install stock throttle body and be ok......
Old May 24, 2004 | 04:39 PM
simple's Avatar
no reason why the stocker wont work, unless its broke
Old May 24, 2004 | 05:29 PM
5.0THIS's Avatar
you might gain 5-7rwhp from a larger one, so I guess it's up to you if you think you need it. A bored stocker (out to 52mm) would more than support the flow needs of your engine, and the stock one is probably not going to be a big restriction with that small cam.
Old May 25, 2004 | 09:05 AM
Guess i'll leave the stock one for now....its not an all out race car...just trying to go a little faster without losing to much drivability....
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
