Thread Sealer?
Old Jan 28, 2006 | 12:31 AM
3gc's Avatar
3gc
Thread Sealer?
What should be used when installing sensors such as oil pressure and coolant temperature sensors? I know GM uses some sort of red thread sealant on the threads of the sensors from the factory but what should I use. Since the sensors get their ground through the threads is something like ARP thread sealant ok to use or will it insulate the sensor from the block and cause faulty readings?
Old Jan 28, 2006 | 12:36 AM
SoloExceptional's Avatar
Re: Thread Sealer?
Is it a sealent or a lubricant? Maybe it's just locktight, that stuff can be Red too.
Old Jan 28, 2006 | 01:07 AM
Dave89IROC's Avatar
Re: Thread Sealer?
the stuff GM uses is a teflon based sealer, you can use any of the liquid teflon thread sealer, but NOT the tape
Jeff1904
Jun 5, 2016 05:00 PM
n2oblkz
Oct 22, 2015 02:31 PM
Double aught
Oct 2, 2015 11:29 PM
Formula Steve
Sep 19, 2015 08:48 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
