thread locker on rotor
Which thread locker should I use on rotor screws- red or blue. Ill be swapping out my opti and will probably be running the ltcc but I would like to keep the rotor in the opti so I have the option of using it or the ltcc for my ignition particularly until I have everything running correct as I either had an issue in my opti or ltcc but had to pull motor back out to deal with leaking head studs.
