thoughts on these rockers?
Old Feb 20, 2007 | 05:34 PM
maybe2fast's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
It seems they are very high quality. what do you guys thing about them? LT1 with hot cam
Old Feb 20, 2007 | 05:39 PM
VK's Avatar
VK
They look pretty good to me. Sounds ok too. They are 1.7 rockers so make sure you get the right valve springs with the hotcam or you'll break a spring or retainer.
They seem cheap... and my rule is you get what you pay for.. those should be 200-300$.. so idk?
Old Feb 20, 2007 | 05:49 PM
89TramsAmGTA's Avatar
Interesting. The bid is for 1.6 ratio rockers but the ones shown are 1.7.
Old Feb 20, 2007 | 05:51 PM
maybe2fast's Avatar
probably generic pics. they seem tempting I need some 1.6RRs
Old Feb 20, 2007 | 06:05 PM
VK's Avatar
VK
I'd try and talk to someone about them before buying them. Make sure you know what your paying for, it is your right.
Old Feb 20, 2007 | 06:17 PM
maybe2fast's Avatar
first off, they are SBC RR 3/8s they will work on the LT1 right?
Old Feb 20, 2007 | 06:22 PM
evilundisguised's Avatar
You'll need guideplates for them to work, since they're not self-aligning.
Old Feb 20, 2007 | 06:27 PM
maybe2fast's Avatar
like these?
http://cgi.ebay.com/ebaymotors/Step-...spagenameZWDVW
would that be everything I would need? I am learning on this valvetrain. thanks for the answers
Old Feb 20, 2007 | 06:47 PM
VK's Avatar
VK
Those will work. You have to have hardend pushrods or those guideplates will cut into the pushrods. I bought a set on this forum for like 50$ w/ guideplates.
Make sure you get the correct valve springs for the cam with the rocker ratio. Then i'd consider getting hardend 7* locks and retainers, i broke a stock retainer and dropped a valve in the motor, i think i spent less then 100$ for comp cams parts from jegs. Worth it, trust me!
Old Feb 20, 2007 | 06:57 PM
mdacton's Avatar
Don't buy this el cheapo stuff.....Those rockers are austalian I think, another company has the same type made in china, I would stay away from cheap knock offs. You really be in a situation when they fly apart......
Old Feb 20, 2007 | 07:04 PM
VK's Avatar
VK
I second that
Old Feb 20, 2007 | 07:06 PM
speed_demon24's Avatar
and they aren't chromoly so they won't be as strong.
Old Feb 20, 2007 | 07:22 PM
2000GTP's Avatar
I would pass on them. If you want a budget set of rockers, I would look for a name brand used set. Plenty of people selling them on here. Also, I wouldn't use a 1.7 roller rocker if you have plans for a cam upgrade down the road.
Old Feb 21, 2007 | 09:03 AM
mzgp5x's Avatar
I am converting to 1.5:1 Comp pro-mag RR's. ($268)
Comp 7/16 studs with larger hex and rolled threads. ($68)
Guide plates from summit ($15)
7.3" 5/16 dia. C_moly pushrods ($86)
Converting from a Crane 3/8 SA RR that are taking a beating from a CM cam 321/240 .538/ .558 lift with 1.5:1 ratio.
The standard chevy guide plates do not fit an AFR 190 head (Valve spacing wider). Trying to modify them now. Are there any documents on this mod???
Those valve cover pics really helped. Thanx.
(97SS 383 - D1)
Old Feb 21, 2007 | 09:16 AM
2000GTP's Avatar
(97SS 383 - D1)
I'm curious, why are you swapping over to 1.5 RRs? Your stock rockers are a 1.5 ratio as well.
