Those using Comp R lifters inside please
When these lifters are set up correctly do they make more noise than other lifters. I set mine to 1/8 turn and it sounded like marbles in the dryer. Is this normal?
Re: Those using Comp R lifters inside please
Once I put in the Comp RRs, the R lifters and the LT4 ED timing set, there
was so much going on I could not say. Definately sounds like a sewing
machine. Lots of sounds to keep things interesting and create false knock.
It's probably equally split among the RRs and the timing set, I doubt that
the lifters are contributing to my under-hood garment factory. Oh yeah, mine
are set at 1/8 turn cold w/ 7/16 studs.
autoxr166
Sep 25, 2015 04:21 PM
