Those trapping around 104 or 105 mph in a 6 speed, What ET?
Old Mar 10, 2004 | 04:44 PM
Serene's Avatar
Hey all
Just wondering, those of you trapping 104 or 105 in a 6 speed, what kind of ET are you getting and with what 60' time?
Thanks a bunch!
Old Mar 10, 2004 | 04:54 PM
brain's Avatar
On E.T. streets the car went 13.3 @ 104. That was boggin bad out of the hole, 2.0 60 ft. Definitely needs more gear. On 245/50/16 junk tires best had been 13.5 @ 105.9 (so close to 106!), with a 2.2 60ft. Got 4.10s waiting to go in, and put on the nittos. Might hit a high 12.
Old Mar 10, 2004 | 04:57 PM
atljar's Avatar
many many mods ago I was running 13.1 at 102.5. High 1.7 60 foots on nitto drag radials and 4.33s.
Old Mar 10, 2004 | 04:58 PM
Serene's Avatar
So you think with 4.10s and a better 60' time on the et streets you can hit 12s? How much does ur car weigh?
Old Mar 10, 2004 | 05:01 PM
Serene's Avatar
atljar, what kind of 60' times do you think I could be able to get with a big clutch dump on et streets with 4.11 gears?
Old Mar 10, 2004 | 05:10 PM
atljar's Avatar
Those times were made with either 5000 or 6000 clutch drops (been awhile and i forget exactly). Car was down BIG time on power (opti and fuel pump both on way out). With the power the car should have had, and ET streets it may have had a touch more in it, but not much.
With 4.10s and the same thing, i dont see why you couldnt pull off some low low 1.80s or high 1.7s too. Suspension was LCA and panhard. Front sway on the car, 17s all around.
You still on stock rear, if so, pray for it and start saving.
Heres a video of that launch. Quality sucks, but you can see how it comes out of the hole.
http://www.atljar.com/Movies/atljar13.1.wmv
Old Mar 10, 2004 | 05:16 PM
Serene's Avatar
How much did your car weigh? No stock rear for me, 9".
Old Mar 10, 2004 | 05:21 PM
atljar's Avatar
I dont have an exact weight.
Whatever a 94 Z weighs with some gas in the tank, stereo in the back, my skinny ***, and a 12 bolt
In other words, nothing has been removed
p.s. Did my link not work? I checked it and it d/l for me
EDIT....just saw i forgot the .com, lol. However, it did work for me still????? LOL
Old Mar 10, 2004 | 05:25 PM
Serene's Avatar
Ya cause mine weighed 3800 with 1/4 tank, some stereo stuff, sfcs and a stock rear.
Did you ever run it on stock tires? If so what did it do
Old Mar 10, 2004 | 05:28 PM
atljar's Avatar
Naw. Ive been running drag radials as my everyday tires since before i even had the gears.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Louey
Pacific
Apr 7, 2015 02:10 AM
canbaufo
Feb 24, 2015 10:27 AM
