Those with pacesetter LTs... (interesting find)
Old Oct 3, 2004 | 11:33 PM
atljar's Avatar
I bought the LTs awhile back, pacesetters. Most likely one of the first sets.
The primary tubes go through the flange, and are welded on the head side of the flange. They then took a mill and milled the flange around the port entrance so that it would seal, but the welds are the highest points so it should give some good pressurre right along the ports.
Anyways, my buddy just put a set of Pacesetters on his car a few weeks ago. They changed the flange style on his. They are made like hookers. Welded on the other side of the flange. On his, the entire flange seals (not just the welds around the ports). They also added a nifty little trademark like the hookers have, cept it says pacesetter From what i could remember by looking at his, and not having mine in front of me, the pipe layout looks the same. They do give better clearance for everything IMO though over my old hooker LTs.
Who has what kind? Anyone know why they switched, sealing problems?
Old Oct 3, 2004 | 11:51 PM
94 CAMRO Z28's Avatar
Re: Those with pacesetter LTs... (interesting find)
Mine are welded on the inside of the flange and haven't had any issues of leaking. I even used the cheap gaskets that came with them. Also, I believe mine has a badge on it saying Pacesetter.
Aaron
Old Oct 4, 2004 | 01:03 AM
95_LT1_6SPD's Avatar
i bought a set not too long after you atljar and they were the same as yours welded on the head side. I always thought it was making a better seal like that. It pushed on the gasket right around the port. I used the gaskets that came with them and they worked fine. Interesting find tho.
Old Oct 4, 2004 | 06:55 AM
Cmr0z28's Avatar
Mine are like that Jared....6 1/2 months since the install, and no leaks (Fel-Pro 1406's, Stage 8 locking bolts)
Old Oct 4, 2004 | 10:12 AM
WS Sick's Avatar
We just put a new set on my freinds T/A and they are welded insid eon the flange, they are much better up top than the hookers I have. They are still sealed with the cheap crapy gaskets that come with them, I was amazed that with this motor they didnt blow out in a few days!!!, but they are still holding.
Old Oct 4, 2004 | 12:19 PM
burnemonm1's Avatar
so all in all everyone is happy with these headers??? if so I'll be ordering mine very soon
Old Oct 4, 2004 | 01:12 PM
WS Sick's Avatar
I know when these Hookers are toast I will be putting Pacesetters back on with a different exhaust set-up.
WildRidez
Mar 27, 2015 08:22 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Jazsun
Dec 29, 2014 12:14 PM
