Third brake light
Old Mar 14, 2004 | 02:51 PM
Jeremy_30th's Avatar
Third brake light
My third brake light went out and I can't figure out what the problem is. First I bought new bulbs and when I was replacing them I noticed that there was some black burns where the bulb inserts.. Is there a fuse for this or is it ran off my reg brake lights? because they are fine its just the one in the spoiler.97 Z/28
Old Mar 14, 2004 | 06:29 PM
HBHRacing's Avatar
power comes from the brake light switch just like the other brake lights. Power to the switch comes from the stop hazaerd fuse. see if you are getting power at the light blue wires to the light with the brake pressed. then see if you are getting ground on the black wire at all times. if both are ok you have some bad sockets or pigtails
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
