Thinking of going from the crane 227 to the xfi 218-244
would this be a gain? the other thing is i'm not sure if the crane spring kit will work with the xfi cam. i have the springs setup to 150-160lbs. on the seat.
Re: Thinking of going from the crane 227 to the xfi 218-244
What is the installed height on the crane springs and I'm guessing they are the 99893 springs.
The XFI cam lobes were designed to work with the 918 beehives so you get the best results and most RPM with them.
Bret
Bret
they have a 1000 miles on them. so yes they are 155lbs. i work at a machine shop and set them up yesterday. also the motor is rebuilt and sitting on the stand. it's decked .002 in the hole .030 over and all the other goodies.
Originally Posted by SStrokerAce
Thats higher than I would expect.
Plus not to mention 99% of the time guys dont know the installed height OR the seated pressure, so forgive me.
Bret
Bret
Because they dont have a clue what pressure or height they are installed at.
The GM846 is tamer than the XFI cam so it's definately going to work. The XFI cam is pushing it the most.
Bret
Bret
