thinking about a built motor?
Old Sep 30, 2009 | 08:32 AM
meangreenchevy's Avatar
My motor has high milage about 125xxx and just recently blew a head gasket... im think either going 383 stroker or a 355 im looking to keep the motor NA with a power output of about 400-450 im looking for something fully assembled ready to bolt in what do you guys recommened or do youse so just send my motor out because there are no local machine shops so im looking to get it back ready to bolt in
Old Sep 30, 2009 | 08:50 AM
green96ta's Avatar
we need to know if this is going to be a dd. but with that goal you can reach 400 rwhp by going 355 bottom end, and if you have intentions of spraying it go forged. then go with a cc306 cam, crane springs that lloyd uses i think they are 10308-1. 1.6rr, and some ported heads. you can get the springs with lloyds LE1 package. they come included. but if your gonna buy from him get his LE1 set up with the custom cam thats made just for the setup. that is good for 400rwhp.
http://www.elliottsportworks.com/lt1.html
Old Sep 30, 2009 | 09:40 AM
dangalla's Avatar
i think golen will be something you should consider. but this is not going to be cheap. dont forget that at that power level you will need full bolt-ons as well
Old Sep 30, 2009 | 10:11 AM
Sry forgot to mention the car will be a dd and I saw the le1 package from another post that I put up but im looking for something fully assembled ready to bolt in... as for bolt ons car already has pacesetter LTs, ory, slp totl 3in cat back and a k&n fipk
Old Sep 30, 2009 | 10:33 AM
slomarao's Avatar
if you want 400rw your going to need good flowing heads to make up for running a smaller cam. I would go le2 heads and a DD friendly cam. Plan on spending 5-7k.
Old Sep 30, 2009 | 11:15 AM
reamo04's Avatar
id say he's looking at more like 8-10k. He wants a full longblock. If he wants 400-450 at the wheels, he is going to have to have 450-500 at the flywheel. That leaves him with the golen 440,480 or golen 520 HP setups
They are 6499, 6899, and 7999 respectively. He than needs to reuse his intake manifold, buy intake mani gaskets. get roller rockers, buy injectors, put on an opti, than headers, TB, etc.
Old Sep 30, 2009 | 05:33 PM
Wow! I wasent planing on spending that much I was looking somewhere between 3-5k... what would you guys say about sending my bottom end out to get rebuilt with all fresh parts and putting on a set of the le1 heads and ported intake manifold
Old Sep 30, 2009 | 05:46 PM
reamo04's Avatar
I would go
rods : scroll down, get the 5140 I-beams
http://gofaststuff.com/rods.html
crank - stock crank
Pistons - http://www.summitracing.com/parts/MLE-SBC550030F05/
right theres a grand. machine work and assembly your probably looking around 600-800.
Leave it 2 bolt mains (unless you have a 4 bolt, just w/e it is, leave it alone your not making the pwer to justify anything)
Than you could send out your heads, get the le2 setup, and get an le3 cam. This will meet your goals
Total -4k or so
Than go to the classifies, pick up 30 or 36# injectors for 250ish
Get a PCMforless tune - 150?
and than w/e for the bolt ons you dont have, your at your goal with a reasonable price. Of course, you can get cheaper pistons, but the mahles are light, and have good rings with them. If you never plan on spraying it, etc, you can get hypereutectics and be fine for much cheaper
Old Sep 30, 2009 | 06:41 PM
bkpliskin's Avatar
Originally Posted by reamo04
I would go
crank - stock crank
Total -4k or so
All good info. A couple of notes. if you can't get used injectors for less than 250 you're better off buying a set of Brand New injectors (F.A.S.T. is what I'm going with) for $300. Check around the net, New 30 and 36 lb-ers can be found new for $300 including shipping. Also, PCMforless tune will run you $175. I drove down to Bryan's house to get mine done since we're both in PA. Not sure what shipping will run you. As far as pistons go, this was pretty much spot on. Even if you stay with hypereutectics you can still spray. I'd just recommend that you keep the size of your shot low.
Old Oct 1, 2009 | 07:25 AM
Thanks guys great info anyone else got anything trying to get as much as possible b efore I dive into a project I can't finish
Old Oct 1, 2009 | 09:12 AM
Anyone ever hear of a company called precision? They have crate lt1s for 3100 with 360hp? And a 383 stroker for 3900?
Old Oct 1, 2009 | 09:17 AM
slomarao's Avatar
go with a proven company that has produced results. Dont try someone new, you may be very disappointed when you all said and done.
If you want 450rw plan on 7k. If you only want 385-400rw you can get away with 4.5k. Are you going to be doing the work yourself??
Old Oct 1, 2009 | 11:02 AM
Going to be pulling the motor myself as far as putting the motor together im going to leave that to a professional and the closet machine shop to me is tune time performance in toms river nj anyone every deal with them?
Old Oct 1, 2009 | 12:35 PM
Sk8phreak88's Avatar
There are a few guys selling there newer built 383's on here in the for sale section for pretty cheap.. That's what i'd do.
D1SC383LT4
Jan 1, 2016 01:56 PM
hotrodyou1
Dec 20, 2014 10:05 PM
ChrisFrez
Nov 23, 2014 10:33 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
