think it may have happened
Old Aug 19, 2009 | 04:14 PM
matt14's Avatar
Unhappy think it may have happened
ok so i recently had the misfires and changed the plugs and it ran better and its been raining here the past few days so i go and crank the car today about 3 times making little trips then i go to a friends and let it sit for mabye not even an hour go out to leave and it wont start right before i got over to my friends i heard a bad squeaking from the belt area.
im pretty sure my opti has finally pooped on me
so do these seem like symptoms of a bad opti?
it will turn over so i know its not the starter and when u give it a little bit of gas while trying to crank it it will try and start but just wont :/
any help would be apreciated
Old Aug 19, 2009 | 07:07 PM
chevyz4life's Avatar
Is the ses light on?
Old Aug 19, 2009 | 09:09 PM
matt14's Avatar
yes bc i have no cats and the rear 02's are plugged but havent tuned them out yet so thats why its been on as far as i know
Old Aug 19, 2009 | 09:17 PM
moparman's Avatar
It would still be a good idea to scan for codes. Might be a new one or two.
Old Aug 20, 2009 | 07:58 AM
matt14's Avatar
well its broke down at my friends right now so ill try and get it scanned as soon as i can then tell u guys what codes it throws
Old Aug 21, 2009 | 10:29 PM
doug1105's Avatar
Talking
Get it scanned for codes first.
If it doesn't throw the exact code for the optical sensor failing, I would say plug wires or you put the wrong plug wire on the wrong plug.
I have a PhD in Optispark.
Old Aug 21, 2009 | 10:48 PM
matt14's Avatar
haha nice!
My dad sprayed some wd40 in the throttle body and i can get it to crank but it wont stay cranked unless i give it some gas..so it just dies.
but yea im tryin to get a scanner so i can scan for codes
Old Aug 21, 2009 | 11:04 PM
doug1105's Avatar
haha
When you crank it can you hear the fuel pump wizzing?
Sounds like ehhhhh from the back seat area.
Next step is hooking up a fuel pressure gauge to the shrader valve on the back of the fuel injector rail to make sure the fuel pump isn't shot.
If there's a ton of miles on the car, you may get really lucky with a clogged fuel filter that needs to be replaced.
My fuel pump died and it did an intermittent slow burn where it would crank and run okay for a little bit and go for a couple of days or so and you're all "it's going to be okay man" and then it died a horrible cold death.
Old Aug 21, 2009 | 11:10 PM
matt14's Avatar
haha
Do u mean when i crank the car up or when i turn the key to the on position?
Old Aug 21, 2009 | 11:25 PM
doug1105's Avatar
Right before it cranks you can hear the fuel pump go ehhh from the back of the car. Sounds kind of like a window wiper washer motor running-
Make sure you get the codes read first, so you don't chase your tail.
I re-read your first post where you said you changed the wires. Check those again and check the opti to coil wire if you changed it.
Look for obvious stuff first.
Old Aug 22, 2009 | 09:19 AM
matt14's Avatar
i changed my spark plugs but not my wires yet
ill scan it for codes 1st before i do anything then tell u wat i get
thanx for the help
Old Aug 27, 2009 | 09:42 PM
matt14's Avatar
ok i finally bought a scanner and scanned it tonight
heres the codes i got...
P0102
P0117
P0134
P0140
P0160
P0300
P0400
P0441
im about to check shoebox's sight for the codes
I also noticed one of the hoses leading down by the opti is leaking coolant bc my fluid is slowly draining out of my radiator
any help guys?
Old Aug 27, 2009 | 10:04 PM
matt14's Avatar
P0102-Mass Air Flow (MAF) sensor circuit low frequency
P0117-Engine Coolant Temperature (ECT) sensor circuit low voltage
P0134-Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 1 Sensor 1
P0140-Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 1 Sensor 2
P0160-Heated Oxygen Sensor (HO2S) insufficient signal activity Bank 2 Sensor 2
P0300-Engine misfire detected
P0400-Exhaust Gas Recirculation (EGR) system
P0441-Evaporative Emissions (EVAP) system no flow (during purge)
the 2 biggest things i see is the EGR and EVAP
Old Aug 30, 2009 | 12:46 PM
matt14's Avatar
Anybody have any idea?
it starts when i give it gas but then just dies if u dont rev it
Old Sep 1, 2009 | 11:58 PM
doug1105's Avatar
When you put the cold air intake on, did you get all of the electrical plugs/connectors back together?
