Think I got the wrong part!
Old Aug 9, 2004 | 02:39 PM
R8E1D's Avatar
Question Think I got the wrong part!
Can a LT4 starter be used on an LT1? I think I had a stupid moment when ordering.
Thanks Red
Old Aug 9, 2004 | 02:41 PM
Re: Think I got the wrong part!
Yes.
Old Aug 9, 2004 | 02:42 PM
R8E1D's Avatar
Ok sweet, the starters look different though do i have to take the guard off the old one or what?
Old Aug 9, 2004 | 02:49 PM
They do look slightly different.
Not sure what you are referring to, though. Mine does not have a "guard".
Old Aug 9, 2004 | 02:57 PM
R8E1D's Avatar
OK cool Shoebox saves the day again!
Thanks Red
Old Aug 9, 2004 | 07:44 PM
Mtrhds94Z's Avatar
Actually, you did a good thing..
LT4 starter is new, as opposed to all LT1 starters are reconditioned...
LT4 is lighter, more powerful, and cheaper...
Should bolt right on..
If by 'guard' you mean the 'dust shield' tin piece that goes over the flywheel/flex plate area, that works for both starters..
Old Aug 10, 2004 | 04:02 PM
R8E1D's Avatar
It was the wrong part or maybe some "rigging" is in order. The Lt1 has three wires and the Lt4 has two. Any ideas?
Thanks Red
Old Aug 10, 2004 | 04:20 PM
Thanks Red
There are only 2 wires that go on the starter (even the LT1 starter). The large cable from the battery and the purple wire from the START circuit. There is a small black/white wire that is a ground that attaches to the block, below the #6 plug.
Old Aug 10, 2004 | 06:33 PM
R8E1D's Avatar
YEP yet another stupid moment. The third wire goes into the starter itself. thanks for all of the help!
Red
novaiiman
May 15, 2016 11:36 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
APS95Z28
Sep 5, 2002 10:21 AM
DarkHorse
Aug 3, 2002 10:17 PM
