Which of these camshafts will rev higher?
Which of these camshafts will rev higher and still performs up top in a built 383 LT1?
Dur @ 050 LSA lift
234/242 112 0.539/0.558
242/248 113 0.584/0.579
248/254 110 0.562/0.580
Dur @ 050 LSA lift
Re: Which of these camshafts will rev higher?
Does that have to do with wider LSA 113. My understanding that tighter LSA will mean more overlap and hence shifting power band up top. I want the engine to rev higher so that it doesn't drop the RPM much when it shifts. I want to shift at 6800RPM all time.
BTW, the first cam is GM847 if you havn't noticed and specs shows it going to 6800RPM. Specs of other two shows 6200RPM. Makes me think something is wrong. Larger duration+ tighter LSA should rev higher.
to make your car rev u really have to get into cam design..... I cant tell u to much without revealing secrets but u can have a 112, 113, 114 LSA with a wide duration and get good revs. i suggest a wide lob seperation with at least a 113 or more so u have that accelerated pushed in your seat feel. i think your car wont rev that well beacuse of the head flow you are getting which is realitive to powerband broadness. my car creates a 443 HP on a 350CI LT1 but my heads flow close to 300 CFM at .600 and my car flies thru the RPM's... I have to shut it down thou becasue i am on a stock bottom end car and my opti shuts off at about 7000 rpms... my tuner told me that he was afraid of pushing anyomre but that the damn thing would pull hard thru 7000rpm... do some reasearch first and call around i can tell u were to get a bad *** custom grind for your set up send me a PM.
Re'
