is a thermostat really needed when running an electric waterpump?
The reason I ask is because I'm in the process of building a remote waterpump with a meziere pump. In order for me to use a thermostat I would have to build a housing for it which isn't going to look good and I'm going for show more than anything on this. Can I just hook up a relay to one of my water temp gauges that has output signals for cooling fans and power the pump with that? Have the pump turn on at a certain temp?
I don't believe in it. I have never run one with my setup and never had any problems. The way I look at it is that the fans do all the deciding on how cold or hot the car stays so who cares about the thermostat.
Besides it's just one less thing to worry about the way I look at it
my car didnt have a thermo when i first got it...
if i drove it to long no mater if both fans were on, it just couldnt cool the water
as soon as i put the thermo in there it stayed at about 200* and didnt have that problem again.
and yes it took my car about 10 miles to get to about 180*
wait, you're saying the car ran hotter with a thermostat? Is that right? A thermostat is closed when it's cold and opens when it's hot. Running with no thermostat should be the coolest way to run the engine. Right?
NO!!!!!
Having no therrmostat will cause the coolant to run through the radiator too fast, resulting in poor coolong of the coolant. It will stay warm, and when it reaches the engine, it will be too warm. Get a 160* stat. My temps stay at 170* at all times, unless I am stuck in in Phoenix traffic for a bit in July when it is 120* out.
so pretty much if I had something in the cooling lines that will stimulate the restriction of a thermostat, I will be ok. I'll just have a hell of a time heating up the engine on cold days
All you people that say don't run without a stat. Is this something you heard or something you tried. I would think it is something you heard, because I have tried it, and there is no difference. Kinda remind's me of the people that badmouth the G2 CAI, something they heard.
Something I tried with my thirdgen, heard in the field and on this forum, and learned in school. Basic knowledge really. It doesn't allow enough time for the radiator to do its job.
