thermo and filter
Old Mar 20, 2004 | 05:37 PM
Punkillr's Avatar
thermo and filter
changing out the thermo and fuel filter. any suggestions?
Old Mar 20, 2004 | 05:56 PM
CamaroSS30thAnn's Avatar
Re: thermo and filter
when u say thermo u mean thermostat ........lol dont get he opti wet lol
Old Mar 20, 2004 | 05:57 PM
OBE1 95Z28's Avatar
Remove your gas cap before removing the fuel filter to take the pressure off the system. One end of the fuel filter has a barbed plastic connector, the other end takes a pair of wrenches to remove. Even with the pressure relieved you're going to loss 10 - 20 oz of gas so have a drain pan handy.
I don't know that you need to change your thermostat as "regular maintenance". If you decide to change it, you might want to consider a 160 degree thermostat instead of the stock 180. If you go 160, you'll need to reprogram the PCM to have the fans come on sooner.
Old Mar 20, 2004 | 06:04 PM
u do not need to reprogram ur fans ur car will still run at a lower temp.......to get the maximum gain out of the thermo reprogramming ur fans would help but it is not a necessity
RedHottG2's Avatar
If you change the stat to a 160 degree, I hope you got the SLP or the Hypertech and not the regular SBC from Autozone (or wherever).
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
colts0455
Sep 11, 2015 06:16 PM
Sep 11, 2015 09:44 AM
