is there a way to verify a lifter is ticking?
Old May 30, 2003 | 02:17 PM
mobleman's Avatar
Without pulling them out?
I've been hearing a tick while driving for the past month or so, after looking everything over I'm pretty sure its not the headers, an exhuast leak, injectors or even the AIR check valves.
Was wondering if there was a spot you could listen to on the engine with the screwdriver trick of engine stethescope to verify a lifter (or something else) as the culprit. So if you've had some handy tricks passed down by an old school mentor, or if you're a venerable old school guy please feel free to chip in!
Old May 31, 2003 | 10:09 AM
arnie's Avatar
Put one end of a pipe to one ear, and the other end on the valve cover.
Old May 31, 2003 | 10:29 AM
Loonies's Avatar
If you take the oil fill cap off while the car is running and the ticking gets louder, it is a lifter. If it doesn't and it is the same loudness it is most likely an exhaust leak.
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
RobFlag
Aug 29, 2015 11:40 PM
