Is there an opti upgrade that deletes it altogether?
Old Nov 6, 2005 | 08:13 PM
  #16
1racerdude's Avatar
Re: Is there an opti upgrade that deletes it altogether?
Ya could run the dual reluctor MSD crab cap distributor,and the ignition control boxes that go with it. Use one reluctor for the the spark timing and one for the injector timing and keep the computer for everything else.
Pricy to go that route but it can be done.
Old Nov 7, 2005 | 01:27 AM
  #17
dhirocz's Avatar
I dont want to go crazy like that. If I was to go with a single plane and such, maybe. I still dont know if the gains on that are worth the hassle so I'll wait on the distributor idea.
The delteq and LTCC look interesting. I've seen a couple good deals on them. How do they compare and do they both work with a ignition box? I have about $500 to spend on a complete ignition, MAX.
Old Nov 7, 2005 | 01:30 AM
  #18
MachinistOne's Avatar
The new MSD pro-billet LT-1 distributor looks very nice, I have never had a problem with msd distributors and I would assume that their opti replacement will be top notch as well.
Old Nov 7, 2005 | 07:18 AM
  #19
Tom Piper's Avatar
The upgrade to eliminate the Opti-Spark altogether is called an LS6.
Old Nov 7, 2005 | 04:16 PM
  #20
mourningyou's Avatar
After that, how do you get rid of the piston slap and oil consumption?
Old Nov 7, 2005 | 05:28 PM
  #21
ejfagala's Avatar
There was a post on the corvette forum from a person who proto typed Delteq's crank trigger system but when I called them I got the run around and it is definatly not available to the public yet.
Here is the link
http://forums.corvetteforum.com/show...88&forum_id=87
blkWidow
May 3, 2015 08:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
ModdedNerd
Feb 5, 2015 04:37 AM
BlackHawk T/A
Aug 28, 2002 03:13 PM
