Is there a ballpark for cam lift/duration that will clear stock pistons?
Old Apr 26, 2005 | 10:54 AM
trax's Avatar
I'm just curious if there's some rule of thumb for how big a cam can be before you get dangerous PTV clearance. Anyone pushing ~.600" and ~240 degrees of duration?
Old Apr 26, 2005 | 01:59 PM
kgkern01's Avatar
Re: Is there a ballpark for cam lift/duration that will clear stock pistons?
I'm not sure what the limits are, but I know that a lot of people on here are running the GM847 cam which has .575/.595 lift and 234/242 duration (int/exh).
Old Apr 26, 2005 | 02:39 PM
97Z-M6's Avatar
its not the lift that gets you its the duration and valve timing. you can have a lift of 2.00"s if you want to, but it better but it better be a real small duration becuase the lenght of time that it is a that hieght is what will get you. the only thing that limits you on lift is the valve length and spring ability. but if your running a stock cast head anyhting over a .600 lift will not benifit you enough to justify the exrta money for springs and pushrods, and ect.
HectorM52
Jul 30, 2017 11:46 AM
Noer
Feb 28, 2015 11:29 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Nov 20, 2014 06:03 PM
