Is there anything I'm missing for this weekends install?
Old Sep 14, 2003 | 08:39 PM
john97z28's Avatar
This weekend I am installing LT4 ported and polished heads/intake, 1.6 RR, Jet Hot LTs and Hooker Y-pipe, 58mm Holley TB, XE cam, R lifters, SVO 30 lb. injectors, and new fuel pump. I will be getting my car dyno tuned afterwards. Is there anything else that needs to be upgraded/replaced? I feel like I'm forgetting something.
Old Sep 14, 2003 | 09:02 PM
JONEZ_Z's Avatar
Might what to put a new timing chain set on while you are at it....And be prepared for a long weekend.......
Old Sep 14, 2003 | 09:12 PM
brandboZ28's Avatar
Timing chain would be a good idea. Also, there are lots of gaskets that are going to be replaced.
Old Sep 14, 2003 | 09:15 PM
LimitedEd1LE's Avatar
How about some new plugs and wires too (if you don't already have them.)
Old Sep 15, 2003 | 12:07 AM
Bud M's Avatar
If you can do all that in a weekend I'll be impressed!
Old Sep 15, 2003 | 08:45 AM
PoorMan's Avatar
What he said. That's alot of work for one weekend. Go for it. I can see it happeneing if you had two guys on it.
Old Sep 15, 2003 | 11:46 AM
john97z28's Avatar
I have new plugs to put in (forgot to mention) and new wires were added at the end of last year before it went into storage. I knew I forgot something...the timing chain. What do you suggest for a timing chain, recommendations?
There will be definitely 2 people, maybe 3 working on it this weekend. If all goes well, it should be completed by Sunday night.
Old Sep 15, 2003 | 11:51 AM
Ryanzee's Avatar
I used the extreme duty LT4 kit.
Expensive but definatly the best.
RYAN
Old Sep 15, 2003 | 11:54 AM
RallyRed701/2's Avatar
if you have a nonvented opti dont you have to do the swap to the vented if you want to use the lt4 timing chain?
Old Sep 15, 2003 | 12:17 PM
Ryanzee's Avatar
Yes your correct.
The extreme duty cam sprocket is for the long dowel pin on 96 newer cars.
RYAN
Feffman
Oct 9, 2015 05:42 AM
Collector Car
Jan 5, 2015 10:58 AM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 1, 2014 08:08 AM
