Is there another bolt hole on the pass. rear side in the head for headers?
Old Nov 7, 2004 | 08:10 PM
94Z28WP's Avatar
I have the stock manifolds... I've been having an exhaust leak for a while and I checked it today... What I thought to be a loose bolt turned out to be a broken one... Somehow the rear passenger exhaust manifold bolt had snapped off flush with the head... The only way I'm going to get that out is to remove the head... I've read some posts that there are extra bolt holes in the cylinder head... Anyone know if there's an extra one for the rear passenger side?
Old Nov 7, 2004 | 10:09 PM
BlackLT1_TX's Avatar
Re: Is there another bolt hole on the pass. rear side in the head for headers?
There are two holes in the back of each of the heads. I guess if you have the manifold or header off, you could have someone weld something to it and drill it and use the other hole.
I dunno!
Old Nov 7, 2004 | 10:27 PM
bodydropped's Avatar
dont laugh but i had something like this happen before.what i did was i used a small bolt a little smaller in diameter than the snapped bolt i held it in the center of the broken bolt and tacked it on with my welder then i took my little 10mm wrench and removed the broken bolt.it took 2 tries but it worked for me,if you have enough clearance try it.
Old Nov 7, 2004 | 11:22 PM
In aluminum, I wouldnt try the above. I could be wrong, but it seems that welding bolts on a aluminum head might seize the bolt for good, and cause bigger problems in the future.
Old Nov 7, 2004 | 11:45 PM
Red on Red WS6's Avatar
I had the same problem when I was putting on headers . On my 96 the exhaust manifold used the hole closest to the firewall I thought I was going to have to pull the head. I did not realize there was another hole in the head and I am still not sure why it's their. But my SLP headers used the other hole and man was I happy.
Old Nov 8, 2004 | 02:08 AM
Z95m6's Avatar
I see a reason to do headers. One way or another you are gonna have to yank the manifold to fix this so i would just do headers.
Old Nov 8, 2004 | 10:38 AM
trans9_5am's Avatar
Why not just try an easy out first? Its worth a try.
Brandon
Old Nov 8, 2004 | 03:20 PM
Z95m6's Avatar
Brandon
Because for that to work he had to be able to get a drill in there to drill a hole in the bolt. That is an almost impossible task. If you want to keep stock manifolds i would try welding a smaller bolt on to the old bolt and unscrew it. The problem is you will have to remove the stock manifold and you will probably end up breaking all the studs off of that for the y-pipe and you will have to replace them. Thats a lot of work when you could just slap some headers on.
Old Nov 8, 2004 | 03:40 PM
trans9_5am's Avatar
I could do it with a 90* drill but i guess it all depends on what tools you have to work with. Anyway good luck with which ever route you choose to go.
Brandon
HectorM52
Jul 30, 2017 11:46 AM
Rod Bender
Jan 1, 2015 03:18 PM
Joes96z
Dec 13, 2014 07:48 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
