Are there Alternator rebuild kits?
Old Feb 26, 2014 | 12:52 AM
iamjames's Avatar
My starter has been whining for a while now and it is showing that it is charging more than it has before. i have had issues lately with new parts giving out (radiator and water pump) and have decided the best stuff is what Chevy put on it in the first place.
I could buy new but if I can do it myself why not. I know there are rebuild kits out there but I have not seen any for an LT1 alternator. Any ideas?
Old Feb 26, 2014 | 02:52 AM
iamjames's Avatar
Re: Are there Alternator rebuild kits?
After some searching I have found them on ebay, only hints at reputable companies online.
Old Feb 26, 2014 | 04:00 PM
iamjames's Avatar
i am actually thinking it may be the power steering pump now, nut the alternator is showing about 15 volts at crank up and when revved it goes down slightly. I still think a rebuild is in my future. At 1/3 the price of a new alternator I am sure a rebuild is the way to go for me. Found a guy on ebay that is selling them at $52, named s-and-d-repair.
CS144 Delco Alternator Rebuild Kit Pontiac Chevy Truck Buick GM Cadillac Olds | eBay
Old Feb 26, 2014 | 05:03 PM
It's normal for the alternator to put out extra voltage to recharge the battery after a start. If your starter is drawing extra power, the alternator may just be responding to a battery that is at low voltage after starting the engine.
Old Feb 26, 2014 | 11:11 PM
iamjames's Avatar
Yeah, but it's been doing it much more notably as of late. Perhaps I am paranoid from it trying to leave me in Kansas. I am thinking now it might actually be the power steering pump making the noise.
Old Feb 28, 2014 | 09:24 PM
ACE1252's Avatar
Measure at the battery for the voltage. Should be around 13.5-14VDC when the car is running. If it's 11.5-12VDC(certainly if lower than 11.5) that could be a cause for concern. Most modern car charging systems produce voltages at the battery of 13.5-14VDC. I can pull some readings off my system with a scope, but that may be too much info.
Any issues with the headlights pulsing at night with engine RPM? If they pulse, you need a new alternator as the rectifiers in it are going bad.
I'd forget rebuilding the alternator. I'm an electrical engineer and I don't bother with going that far with mine. I think I got my last alternator at Autozone years ago and it's been fine. Could be a fun little project, but I'd just assume get a "new"(rebuilt one I expect) one with a warranty.
The power steering pumps can make quite a bit of whining noise when bad. They can even be bad when new!!! Ask me how I know!
blac94Z
29
Mar 25, 2015 04:21 PM
transam_388
Mar 15, 2015 11:53 AM
armedtrigger
Feb 24, 2015 08:30 PM
chuyz28
Nov 25, 2014 11:14 PM
