Thanks Lloyd and a few questions for you guys
Old Jul 2, 2007 | 08:57 AM
  #16
SS RRR's Avatar
If you can, e-mail the dyno sheet to me. I really think you have some gearing/top end issues that need to be addressed.
And yes if you're going to spray then stick with what you got.
Old Jul 2, 2007 | 10:58 AM
  #17
Z-RATED94's Avatar
Scanners not working. When you say, stay with what you have, do you mean the 2800 Vig. or is it ok to get the 3600 Yank and still spray a 100 shot without running out of gear?
Old Jul 2, 2007 | 07:24 PM
  #18
SS RRR's Avatar
If you are using that car for N20 passes then you probably want to stay with the gearing you have w/ a 26" tire. Converters? I wouldn't have the foggiest clue. The 2800 might be too tight of a converter to get the most out of a nitrous pass. Just depends on what you want. I'm not sure nitrous converters are all that street friendly. Better to ask someone w/ more auto/nitrous experience. Perhaps on the N20 board?
Old Jul 2, 2007 | 08:12 PM
  #19
speed_demon24's Avatar
Actually nitrous converters are more street friendly since they act like a tighter stall on motor.
Old Jul 2, 2007 | 08:40 PM
  #20
ABA383's Avatar
I think a 3600 would be a good choice...Ideally you want a converter that stalls 500-700 rpm (some go as high as 900 rpm) below your torque peak...I think the 2800 is to low...I have a Joe O. 226/234 and run the Vig 3600 with a 3.73 gear...I'm not going to spray it so I'm switching to 4.10s and a 28" tire...But for now I'm 60'ing 1.55 fairly consistently...The mph bubble for 11s is around 112...You should be there...Its interesting to see how much your car picks up from the 1/8th on out...
--Alan
Old Jul 2, 2007 | 09:34 PM
  #21
Z-RATED94's Avatar
It's quite amazing how hard it's pulling on the top end. I can't believe a 222/226 cam could pull that hard. Maybe Joe O. does know something about cams.
Old Jul 2, 2007 | 10:37 PM
  #22
tireburnin's Avatar
Not doubting any of the parts designers, but I would assume you are having a problem down low...not a fantastic back half. If that is true you have gains to be had. How is your tranny fluid?
Or I could be wrong and it back halfs like a 6spd car.
Old Jul 2, 2007 | 11:34 PM
  #23
SS RRR's Avatar
I thought they were looser.
<------ doesn't know di(k about converters.
Old Jul 3, 2007 | 10:00 AM
  #24
Z-RATED94's Avatar
ABA383, the car was going to Speed Inc. for some little stuff on the 24th of this month. It was some stuff I can live without for now. Instead I'll spend my limited funds on the 3600 Yank. That and I'm having some tabs welded on the axle tubes so I can triangulate the rearend. I already have all of the pieces needed to do so. I'm trying to make this 10 bolt live for a while.
tireburnin, with the Yank and pulling a hundred pounds out of the car, plus lowering the 2-3 shift, maybe my first half will pick up enough to pull off a high 11. As far as the stock trans goes, (does a shift kit count) I guess I should check the fluid. It was flushed 2k miles ago and was a tad burnt, but just barely.
Thanks for the replys guys, any "guesses" on how much the higher stall will help my ETs?
Old Jul 3, 2007 | 07:01 PM
  #25
SS RRR's Avatar
Depends on your torque peak. I was thinking about it and if you're going to spray you may need to get a larger tire or gear to something less than 3.73.
Old Jul 3, 2007 | 08:21 PM
  #26
Z-RATED94's Avatar
Or maybe, just use it in second and third gear.
Old Jul 3, 2007 | 10:30 PM
  #27
SS RRR's Avatar
May not be enough... worth a shot I reckon. The last thing you want to do is end up over your hp peak crossing the traps.
Old Jul 3, 2007 | 10:43 PM
  #28
Nah they act tighter on motor, for example a 5000 stall converter on nitrous might only flash to 4000 on motor. That's just an example, it will obviously vary from combo to combo. I know my friend was looking at a 5600 stall on nitrous from neil chance and it will only stall to ~4000 on motor or something like that.
Old Jul 4, 2007 | 08:03 AM
  #29
ABA383's Avatar
If you are not able to get it on the dyno to see where your torque peak is I would consult Yank to see what stall speed they recommend for your combo and goals...
--Alan
Old Jul 4, 2007 | 10:01 AM
  #30
Z-RATED94's Avatar
--Alan
Torque peaks at 5400, and thanks, I will call Yank. I'm sure I don't want to run anything bigger than the 3600 for drivability concerns. Plus I hope that it won't be to much converter if I spray a 100HP shot. I'm not switching gears or tires to make this work. I'll just have to figure out when the nitrous should kick in to coincide with what I have to work with.
