tfff tffff tffff what is htat
Old Apr 30, 2004 | 04:32 PM
Z28Boss's Avatar
tfff tffff tffff what is that
My car makes a sound that is like tfff tff tfff tfff tfff when the engine is cold and it is slightly cold out. It sounds like it is coming from the passenger side of the engine. I think it sounds like an exhaust leak but it goes away after driving a little. Could it still be an exhaust leak. My car also has a rough idle. Could that be causing it since the leak is probably before the O2's. I also have bosch O2 sensors and I know that is bad. Let me know.
Old Apr 30, 2004 | 04:59 PM
Cmr0z28's Avatar
Sounds like an exhaust leak to me....take a piece of vacuum hose and use it like a stethascope to track down where the ticking is coming from. Do it while the engine is cold and it will tell you where the leak is coming from. Good luck.
-Matt
Old Apr 30, 2004 | 05:01 PM
Better check your spark plugs, too.
Old Apr 30, 2004 | 05:55 PM
Z28Boss's Avatar
Hey shoebox, the plugs wouldnt cause the sound though right?? Also, how do I use vaccum hose to find the leak?? I dont really understand that part.
Old Apr 30, 2004 | 06:26 PM
Cmr0z28's Avatar
Is it a ticking sound? Ticking could be an exhaust leak, ticking injectors, loose spark plugs, failing lifter(s), etc.
Old Apr 30, 2004 | 06:27 PM
dnz28's Avatar
loose spark plugs allow what is in inside the cylinder which build compression well if a spark plugs loose it allow the compressed gas to escape since it is no longer air tight.
Old Apr 30, 2004 | 06:35 PM
Z28Boss's Avatar
I dont think its a lifter. I have heard that sound before. How do you go about finding an exhaust leak. Its also about time I change my sparkplugs too. I have AC Delco plats in the right now and they have been in there for about 4 years. Is it about time to change them??
Old Apr 30, 2004 | 09:06 PM
A loose one will sound just like that. That's why I said to check.
Plugs 4 years old should be changed.
96LT1TX
Sep 10, 2010 09:44 AM
DurangoSickk
Apr 6, 2006 10:35 AM
turbo_Z
Jul 20, 2005 10:41 AM
