testing injectors
Old Aug 18, 2005 | 12:37 AM
lt1street's Avatar
testing injectors
I have been posting for the past few days trying to get a miss i have figure out, THANK YOU for the replays on the earlyer stuff. Heres the question is there a way to make sure that the injectors are working right beside useing a noid (spelling) light to check pluse, and meter checking resistants of the injector???? Im trying to see if i have a pluged injector or something leading to a miss , just buy elemination.
Old Aug 18, 2005 | 07:53 AM
Chris 96 WS6's Avatar
Re: testing injectors
Swap all the injectors from one side to another. If the miss moves to the other side of the motor, then you know its an injector.
Old Aug 18, 2005 | 09:32 AM
ZMAN Z28's Avatar
Un plug the coil wire (You don't want the car starting). Pull the fuel rail up so the injectors are out of the intake. Have someone turn the car over and observe the injectors spraying. They should look like a conical mist coming out. It will happen so fast the spray will look steady, but you can tell they are pulsating. If you check fuel pressure, then you have troubleshooted your fuel system.
ZMAN
AdsoYo
May 2, 2018 03:21 AM
naaz90
Jul 27, 2002 08:22 AM
