Testing ignition control module?
Old Jan 29, 2006 | 03:29 PM
RICEFEDZ28's Avatar
Is there any way to test the ignition control module on an LT1?
Old Jan 29, 2006 | 03:43 PM
Guest47904's Avatar
Guest
Re: Testing ignition control module?
sure check for ground on pin C. With KOEO, 12 volts at pin A & D. Now crank it over and see if you have 1-4 V AC on pin B. If you do and the coil still has no spark, it's probably bad.
dluna333
15
Mar 13, 2015 12:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
Cam28_boy
Aug 6, 2002 08:40 AM
