Testing for a bad opti
Is there any way I can check my opti to see if it is bad? I am haveing problems with my car and I think it is the opti, but I would hate to replace it if it isnt bad. Thanks for any help.
The optical part sends a high resolution and a low resolutoin signal. If you connect an oscilloscope to each and see missing steps(the voltage changes as each hole passes the sensor) then your opti is bad.
ad356
Apr 11, 2015 10:30 PM
