Tensioner
Old Sep 10, 2005 | 03:39 PM
TJ Chapman's Avatar
Tensioner
How do you adjust the belt tensioner on the LT1? I put a A/C delete pulley on and now my belt seems loose, and it squeeks. The tensioner is right next to the A/C puylley. How can I tighten it?
Old Sep 10, 2005 | 03:49 PM
Dave89IROC's Avatar
Re: Tensioner
is it still spring loaded(really stong spring)? there is no way to adjust the tensioner, it is automatic
you either need a new belt or a smaller belt, or the tensioner is weak
does the belt feel tight with the engine off?
Old Sep 10, 2005 | 04:09 PM
TJ Chapman's Avatar
Re: Tensioner
does a squeak mean the belt is loose?
Old Sep 10, 2005 | 04:16 PM
Dave89IROC's Avatar
Re: Tensioner
not neccesarily, the belt could be glazed or just worn out
go to the store with the belt on it now and see how much difference there is in length between old and new, probably a good bit if the old belt is more then 2 or 3 years old
Old Sep 10, 2005 | 08:01 PM
TJ Chapman's Avatar
Re: Tensioner
I just went and bought a new belt. It went on in two seconds once i figured out how exactly to lower the tensioner. It then tightened itself up very well. It's much tighter than the sqeaky one. And now. . . no sqeak. and no A/C! Thanks.
HectorM52
Jul 30, 2017 11:46 AM
pimpen1024
Aug 19, 2015 08:36 PM
4586
Aug 18, 2015 07:08 AM
Catmaigne
Jul 14, 2015 05:17 PM
InjectedSS
Advanced Tech
May 4, 2003 05:53 PM
