Temp Light flashes on after Driving
Old Apr 4, 2006 | 09:00 AM
EXXON2's Avatar
My temp light on the gauge flashes on when I drive. This happen before when my radiator was low af antifreeze. I checked fluid level and the radiators full. The temp gauge is normal and no leak of antifreeze. Could this be just a gauge malfuntion. Please give me some advice.
Old Apr 4, 2006 | 10:03 AM
Re: Temp Light flashes on after Driving
Do you mean the "low coolant" light is coming on? If you had a high temp problem, I think the "check gauges" light would be on. The coolant level sensor is a notorious problem on the LT1's. The sensor gets plugged up or fails, turning on the low coolant light when the radiator is full. You can try cleaning the sensor, or replace it, or simply disconnect it to turn out the low coolant light. The sensor is on the back of the radiator end tank, a few inches below the fill cap.
Old Apr 4, 2006 | 12:09 PM
EXXON2's Avatar
Thanks Injuneer for your advice. I think I'll disconnect for now. I'll check my coolant before I drive her.
Old Apr 4, 2006 | 12:15 PM
TobyZ28's Avatar
To clean the sensor just drain the radiator down below the level of the low coolant sensor and just pull the sensor out. It should be pretty obvious which part of it to clean....
There is a retainer clip you need to take off first
Jan 23, 2015 01:13 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
