Temp?
Old Mar 30, 2003 | 10:51 PM
speed76demon's Avatar
Temp?
What happens if your car gets to hot?? I know general question but i want to know the answer
Old Mar 30, 2003 | 10:58 PM
RENE95Z's Avatar
Warp your heads, blow a head gasket, in general, F**k your car up.
Old Mar 31, 2003 | 02:02 AM
Wild1's Avatar
Always watch your gauges. But even your sensor or connection could be bad. Check your coolant level often and never use plain hose water with all of those deposits. Doesn't do any favors to the engine. Use either radiator water or distilled water from the grocery store only.
Old Mar 31, 2003 | 06:46 PM
Can you tell when you blow a head gasket or warp your heads??
Old Apr 1, 2003 | 11:25 AM
Wild1's Avatar
Best way to check is with a leak down tester. But with any tester including a compression tester, you will need straight access to the spark plug holes. In my case with the Edelbrock TES headers, it will be very difficult. I would have to remove the headers to check each spark plug.
Essentially, it is a guage that will screw into your spark plug hole. For the leak down tester, you will pressurize the cylinder with compressed air and both valves closed. It will indicate a leak and you can determine if it is the gasket, rings, or valves that are bad. This is the short story but there is much more detail.
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
damnyankee36
Sep 9, 2015 07:06 PM
