tell me what is wrong...also rebuild prices in Orlando Florida.
Old May 25, 2004 | 10:20 PM
Caps94ZODG's Avatar
Angry tell me what is wrong...also rebuild prices in Orlando Florida.
okay first off I have no space to pull the engine I live in an apartment so the do it yourself thing is out.
now tonight on the way to pick up my paycheck I overheated and it started to bog down.
so I let it sit got picked up by my fiance and went to get my check, so I went on back to the car. checked the fluid levels put some more coolant back into it that replaces the stuff that splooged all over the place.
at this time I notice the smell of almost roadkill comming from the oil cap as I checked the oil, nothing but a funky smell, so I figured I overheated, and we tried making it home. well it had the SES light come back on and it started overheating again pulled over and smelled the nasty oil again...
now almost home I start hearing the clack clack or something in the engin and no oil pressure. check guages light comes on and its got no power. no oil pressure, overheating and a clacking sound. the oil cap was smoking like crazy like burnt oil, and the rad was overflowing again.
my engines cooked I would imagine..and now I ask how much for a rebuild in Orlando Florida. any reputable shops that can give me a break or deal on someone thats down on his luck, I am really in the poor house and this just crucified me.
Old May 25, 2004 | 10:54 PM
LukeZ28's Avatar
Ouch, sorry to hear, but im not to familiar with orlando.
Old May 26, 2004 | 04:57 AM
Caps94ZODG's Avatar
thanks this is the most unbelevable thing I can go through right now. things really suck..
taking to the top for the morning crew.
Old May 26, 2004 | 05:27 AM
slopokrodrigez's Avatar
Sorry about your bad fortune.
Don't bother to use local shops for a rebuild unless you know someone personally. Too many horror stories about rebuilds. Your safest bet if you don't want to go Hi-po is to get a Jasper replacement. They have shops that will sell you the remans everywhere and they are warrantied terrific. If you want to save some money, you could get a short block but I don't know for sure if Jasper sells SB's. There are other sources for SB's as well. Golen is one. Obviously the less you buy (the more you save) but you will have more work to do yourself. If you buy a SB, you will still have to have the heads done. Not to mention you still have to swap the fuel system and ignition system as well.
I don't know your financial situation but you could look for a used engine. Look in the paper, trading post or with wrecking yards. With this route, there are obvious risks.
Good luck.
Old May 26, 2004 | 08:59 AM
JIMS1999CONVZ28's Avatar
Post in the FLORIDA Section of this board
Try posting this in the Florida section of this board.
LT1 engines are hard to come by here (short blocks).
I have not checked salvage yards.
I got my bare block from a machine shop here in Orlando.
You would be better off purchasing a used motor with a warranty if you can find someone that would do that.
Check Summit or internet engine 'sellers'.
I could have bought a 502 for what I am putting in my 383!
Jim
Old May 26, 2004 | 03:41 PM
Caps94ZODG's Avatar
thanks guys, yea was thinking about doing a replacement from someone..the whole thing too...just gotta find an LT-1 to replace..and to rip out and install and do the wiring. man what a disaster..and no I have no money to do anything at all. Like I said its pretty much icing on the cake...Im broke and money is not there..and my car now dies.
Old May 26, 2004 | 07:14 PM
LukeZ28's Avatar
The spot in SFLA
http://tacreationsusa.com/
LeftoverChinese
Jan 14, 2024 03:03 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
transam_388
Mar 15, 2015 11:53 AM
